A power bank keeps your phone charged wherever you are, whether you're commuting, travelling or simply away from a plug socket. Choose a compact power bank for everyday top-ups, a high-capacity model for longer trips, or a fast-charging or wireless power bank to suit how you like to charge. Free 1 day delivery on every order.
Please note:
The estimated delivery dates shown below are for
guidance only.
During periods of high demand, deliveries may take
longer than usual.
Staying charged on the go shouldn't be a hassle, which is why iD Mobile stocks power banks from a wide range of trusted brands, so you can find the right capacity and charging speed for your needs, with free 1 day delivery on every order. iD Mobile is brought to you by Currys, so you can shop with confidence knowing you're backed by a well-known retailer.
A compact power bank is small enough to slip into a pocket or bag, making it ideal for everyday top-ups when you're out and about. Lower capacity than bulkier models, these power banks are built for convenience over sheer battery life, giving your phone just enough charge to get you through the day.
If you need more charge to go further, a high-capacity power bank can top up your phone several times over, or charge more than one device at once. With a bigger battery inside, these are a good match for long journeys, festivals, or any time you're away from a plug socket for extended periods. Check out our accessories bundles if you want to protect your phone and top up your charge for less.
A fast-charging power bank gets your phone back up to a useful level of charge in less time, using USB-C or USB-A ports designed for higher output. They're a practical choice if you're always on the move and can't afford to wait around for a slow trickle charge. Pair yours with one of our chargers for a speedy top-up at home too.
Our MagSafe power banks attach magnetically to the back of your iPhone, giving you a wireless top-up without a single cable in sight. Just snap yours into place and go about your day, whether that's charging on your desk or on the move. They're compatible with iPhone 12 and later, and pair nicely with a wireless charging-compatible phone case if you want to keep the magnetic connection strong.
Terms and conditions
