Tell us if you're calling abroad from the UK, or roaming abroad.
Tell us the country that you'll be calling or travelling to.
View a full list of the prices for the country you selected.
You’ll be subject to ‘Maritime roaming’ charges, even if you’re travelling between any of our ‘Inclusive Roaming’ destinations. For more information, and to view the charges, select ‘Roaming’ above, and then ‘Ships, Ferries, Cruise Liners’ on the dropdown.
Select a destination from the drop-down list to see to how much it costs to call or send a message to it.
Whenever you call or message this destination, make sure you enter the dial code exactly as it appears below. If you use a different dial code, we might not recognise it and charge you extra.
International dialing code: -
The table below shows how much you'll be charged when you contact the destination you selected above from the UK.
Prices are shown including VAT where applicable.
Select the destination you'll be roaming in to see how much it costs to use your phone when you're there.
The table below shows how much it costs to make calls, send texts and use data in your selected country.
If you're roaming in one of our 50 Inclusive Roaming destinations, the minutes, texts and data you use simply come out of your remaining monthly allowances.
*See our list of Band 1 and Band 2 destinations under Related FAQs
When you’re at sea, we strongly recommend you don’t use your phone, and put it into flight mode until you get to shore. We’re advising this because roaming charges at sea can be very expensive.
If you’re going on a cruise, or taking a ferry on a journey like Dover to Calais, roaming charges could apply, even if you’re travelling between any of our ‘Inclusive Roaming’ countries.
The reason for this is because ferry and cruise operators often use their own phone network that’s operated via satellite. Connecting to a satellite network is much more expensive then connecting to a land operated network, so that’s why your usage at sea isn’t included as part of your Inclusive Roaming allowance.
Here’s a table showing the costs of roaming at sea:
To avoid these high charges, we’d advise you not to use your phone when at sea. Just pop it in flight mode until you reach land.
Some ferry and cruise operators offer Wi-Fi on board, and you can still connect to Wi-Fi when in flight-mode. Simply go into your settings and manually turn on Wi-Fi.
Roam like at home in 50 destinations throughout Europe and beyond.
We've designed the iD App to help you manage your account, even when you're on the go. Stay in complete control at all times.
