Get your settings.
Phone & Device settings
All mobiles bought from iD should arrive with the right settings already configured.
If you've moved over to iD on a SIM only plan and kept your phone, you may need to review the settings to get things like the internet and picture messaging working.
Back to top
Check / Send me my settings
The quickest and easiest way to get your settings is to use our special settings checker. All you need to do is enter your details and select which phone you're using.
Click to go to the Settings Checker.
Back to top
Manual Settings
If you have any difficulties with the automatic tool, or if you're a technical whizz, you may prefer to use the information below to set up your phone.
Name iD
APN id
Username <leave blank>
Password <leave blank>
MMS Proxy
MMS APN Username <leave blank>
MMS APN Password <leave blank>
MMS Port 8799
* anything with <leave blank> should be left blank
Back to top
